davidc
Best Exhaust For Standardish 205 1.9 8v Gti ?
davidc
Right guys....I've been searching the forum for the last hour or so but not having much luck !!
What's the best exhaust system for a 205 1.9 GTi thats basically standard, also, what downpipe is best ?
The car will be used for track/rally use.
Also, where is best to buy from ?
I've been told to make sure that we get a downpipe that is split rather than just being an open bore.
Any help would be greatly appreciated !
Thanks,
David
woo83
I'd keep with a standard OE Peugeot exhaust system, just make sure its in good nick and clean. I know loads of people who swear by them, especially if the rest of the engine is standard.
John
davidc
John
Do Peugeot still supply them ?
Thanks,
David
Thanks,
David
Yes, or they did a year or so ago but they are pretty expensive(~£250 for the front half on the later two piece system & £85 for the back box).
The usually agreed best option is an Arvin exhaust as these follow the proper oe twin siamiesed downpipe & quality exhausts but you have to state that you want an Arvin one because they are part of the same company as Timax but the Timax systems aren't as good.
I run an Arvin system on my GTI which mainly sees use on track with slightly more power than a standard 1.9 8v & its better than it was when I ran it with the Peugeot Sport group N system previously.
The standard system is good for over 160 bhp & is used on some high power Mi16's people on here run.
Graham.
davidc
Graham.
Thanks for the info.
I presume the Arvin system & downpipe should be available from most motor factors ? Any idea how much they are ?
What are the Ashley systems like ? I believe there is a 2" version & a Competition one that is 2-1/4" ? Any thoughts or experiences ?
Cheers,
David
DamirGTI
I run an Arvin system on my GTI which mainly sees use on track with slightly more power than a standard 1.9 8v .
Graham.
Ditto :lol: good price and quality build ..
Damir
dylbachgti
Damir
timax fella i paid 105 for a centre and back box standard bore improved my car dramatically to be onest ,and no waking the neighbours early in the morning
i thought about going genuine but to dam expensive i had one off ces uk hope this helps if u want the part numbers i can help
boombang
Last Arvin system I bought was in region of £120 included VAT, with a little discount on list prices applied.
http://www.buypartsby.co.uk/
Go for later spec 2 piece system for cheapness, or 3 piece in case you mash a bit of it (then only have to buy a third not half!)
Paul_13
I had an ashley exhaust, and f*ck me it was tooooo loud.
I had the 2" outwards rolled backbox, looked nice.
dylbachgti
here are the part numbers pg140
pg139 good stuff easy fit no hassle hope it helps
richsmells
That's where I got mine from last. You can fill out the comments/notes field when you order to tell them to supply the Arvin one.
Fitted mine in the rain at night by torchlight. :ph34r:
Edited by richsmells
Ludi
John
I agree,keep it std.
