Oigen 9 2 Cars Posted May 22, 2010 Hi, Does anybody knows what relays should be here? My car doesn't have the left one, are just two blanks there. Thanks for any replies Share this post Link to post Share on other sites
ade 4wd 11 Posted May 22, 2010 Going from left to right:- 1-Driving lights 2-Not used on a 205 3-Front screen wiper delay 4-Indicator/Hazard 5-Electric windows 6-Heated rear window Share this post Link to post Share on other sites
Oigen 9 2 Cars Posted May 23, 2010 (edited) Is it possible that the second one to be for heated seats? I know that in cold countries it was available this option. I am asking this because I am trying to fit heated seats on my car. I discovered that if I put a relay in this position is working exactly like the one for electric windows and does a "click" when I start the engine. Also I discovered that this relay is needed for the blank conection with 3 pins above the first relay. Any ideas? Edited May 23, 2010 by Oigen Share this post Link to post Share on other sites
ade 4wd 11 Posted May 23, 2010 Yes you could use the second relay for heated seats but i dont have the wiring diagram. Share this post Link to post Share on other sites
Capn. Pugwash 0 Posted May 25, 2010 Yes you could use the second relay for heated seats but i dont have the wiring diagram. I've got the diagram at home so I can check for you tonight. I used this relay position to run a second fuel pump with a surge tank. For memory, it receives power through fuse 4 and the other 3 connections are on a white plug on the left hand side of the box. I'll check tonight and let you know, but it works perfectly for my application Share this post Link to post Share on other sites
Oigen 9 2 Cars Posted May 25, 2010 From what I have checked... This relay(second one from left to right) operates when I start the engine just like the one for electric windows and it gives +12V on pin number 3 from the blank 3 pins plug(picture attached). Pin number 1 and 2 from this plug have +12V with or without this relay. This relay receives power trough fuse number 3 May you upload the wiring diagram for this relay please? Many thanks, Share this post Link to post Share on other sites
Capn. Pugwash 0 Posted May 26, 2010 (edited) From what I have checked... This relay(second one from left to right) operates when I start the engine just like the one for electric windows and it gives +12V on pin number 3 from the blank 3 pins plug(picture attached). Pin number 1 and 2 from this plug have +12V with or without this relay. This relay receives power trough fuse number 3 May you upload the wiring diagram for this relay please? Many thanks, Here we are You can see my annotations on the second diagram for the fitment of a second fuel pump. I was a bit surprised that these diagrams only feature in the Haynes Owners Workshop manual (which incidentally, I can't find a PDF of anywhere!) and not in the Haynes Service and Repair Manual (of which I can find heaps of links for!) 205_Relay_and_fuse_board_layout.pdf Edited May 26, 2010 by Capn. Pugwash Share this post Link to post Share on other sites
Oigen 9 2 Cars Posted May 27, 2010 Thank you very much Share this post Link to post Share on other sites
welshpug 1,619 Posted May 27, 2010 I think the 2nd slot from the left is used in the 309 for the horn relay, this is in the engine bay of a 205 if memory serves me correct. Share this post Link to post Share on other sites
Capn. Pugwash 0 Posted May 29, 2010 (edited) Any idea where abouts in the engine bay? Edited May 29, 2010 by Capn. Pugwash Share this post Link to post Share on other sites
ade 4wd 11 Posted May 29, 2010 A far as i know only 1.9 205s that had a air horn had a relay. The relay can be found in the engine bay next to the header tank. Share this post Link to post Share on other sites
Dariooo 5 Posted June 3, 2010 Here we are You can see my annotations on the second diagram for the fitment of a second fuel pump. I was a bit surprised that these diagrams only feature in the Haynes Owners Workshop manual (which incidentally, I can't find a PDF of anywhere!) and not in the Haynes Service and Repair Manual (of which I can find heaps of links for!) Hi Have you maybe got some more wiring diagram or only a number of wire and where are they going? I'm would check if it's everything ok with wire for relay of indicator and hazard...do you maybe know where are going some of four wire? I have a problem with hazard and indicator. They not work Thank you Share this post Link to post Share on other sites
Oigen 9 2 Cars Posted June 6, 2010 (edited) Hi, With the diagram from Capn. Pugwash and the diagrams from Haynes you can see whre the wires are going and their numbers. Hope this pdf will help you... Body electrical system - Haynes Edited June 6, 2010 by Oigen Share this post Link to post Share on other sites
rubyna 4 1 Cars Posted June 6, 2010 (edited) edit Edited June 6, 2010 by rubyna Share this post Link to post Share on other sites
