jackherer 543 Posted June 5, 2010 I thought my shell was all sorted and I was about to start rebuilding it when I found some hidden rust, I've not seen a 205 rust here before, especially as the rest of the shell is solid. It was covered in painted seam sealer and there was no sign of anything wrong, the only reason I spotted it was a tiny orange spec on the inside within the seam but it turned into the hole in the pic after I started poking at it. The timing couldn't be worse, I've just had it transported back here where I don't have any welding equipment, it was away having the cage welded in and it looks like it needs to go straight back. Share this post Link to post Share on other sites
Tom Fenton 1,524 Posted June 5, 2010 Get it all prepped and ready and then get a mobile welder to come to you. If it is all prepped then it is 20min to weld it in max. Share this post Link to post Share on other sites
boombang 2 Posted June 5, 2010 If you can get mains power at the car, you're welcome to borrow my welder mate. It'll do bodywork a treat. Share this post Link to post Share on other sites
jackherer 543 Posted June 5, 2010 Tom, I know but I hate paying people to do things I can do myself, if I could get it to my mates I could do it there but I've just paid to have it towed two ways and I can't bring myself to do it again. Alex, thanks, that is a great offer, I'm trying to call in a favour with a mate at the moment but if that doesn't work out I might take you up on it. Is nobody else surprised at that hidden little patch on an otherwise solid shell? Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted June 5, 2010 I know Mile's has a Phase 1 with most of the scuttle gone but that shell has other problems as well. Bit surprised really, did it look like original seam sealer? Share this post Link to post Share on other sites
jackherer 543 Posted June 5, 2010 The sealer looked identical to the other side, there wasn't even any indication it was rusty, it only showed inside with the dash out and even then it was just a hint of orange in the seam that I thought was just a mm or two of surface rust. Share this post Link to post Share on other sites
DamirGTI 323 Posted June 5, 2010 I've not seen a 205 rust here before, I did and had just the same on my red , rusty rocket bar the rest of the iron oxide infection of course , this one was just "a blemish" ! Damir Share this post Link to post Share on other sites
