chipstick
Header Blockage Bung
chipstick
I am about to fit my Baker BM hoses, and I am using the Ph1 header tank. After realising I don't have enough hoses for all the expansion tank outlets, I have had a search and realise I need to block the 3rd outlet off.
The easiest way to get around this would be to use a ph2 tank?, but I want the quicker option of blocking it off. I see someone mentioned a ZX airbox bung :lol: Is this the best route? Do Citroen sell them new? A part number would be appreciated if anyone uses Citroen's version of servicebox.
As it is going to be under some pressure I want to use something fairly substantional that doesn't fly off and leave me at the side of the road!
Edited by chipstick
phase 2 black header tank has the same number of ports, so fitting that wont help, the level sensor works differently anyway so you can't use it.
what size is the port you need blocking?
Stu
I used the bit you have to chop off the heater hose and a dump valve bung i had knocking around ;)
Edited by Stu
marksorrento205
Post up what size you need. I have a list here of a selection of differnt size pug blanks
chipstick
Some good options!
The metal end is 15mm
And the lower plastic bit is 17-18mm
marksorrento205
Both these are female blanks to blank off a male outlet
14mm 131984
17mm 135504
(pug part no's )
chipstick
That is bloomin fantastic! Thanks for that :)
131984 isnt a bung, its a clip :unsure:
135510 is a bung though, £2.53.
135504 is £2.20.
chipstick
I am going to go for the 135504 17mm varient and cut off the narrower metal end if needed.
Will see how it goes and report back.
marksorrento205
135504 is £2.20.
Correct welshy. My mistake!! I read the part no from the line below on my list :(
