Toddy
Xu10J4Rs Compression Info
Toddy
Following on from the thread below regarding XU7 Info by Sandy. I am assuming the piston crown volume and chamber volume for XU7 AND XU10J4RS to be the same for the calcs below.
http://forum.205gtid...me&fromsearch=1
XU7 XU10J4RS
Piston Crown Total volume (dish & Cutouts) 2.0cc 2.0cc
Gasket Volume (1.4 x 84 or 87mm) 7.8cc 8.3cc
Chamber Volume 37.2cc 37.2cc
Swept Volume 440.25cc 499.5cc
Compression ratio
440.25 +(2+7.8+37.2)/47 = 10.4
499.5 + (2+8.3+37.2)/47.5= 11.6
Working back as we know that the GTI6 ratio is 10.8 gives
499.5 +51/51= 10.8
Where is the extra 3.5cc? Do the GTI6 pistons rise flush with the block at tdc or are they roughly 0.6/7mm below the deck of the block giving an extra 3.5cc to the piston crown volume (also GTI6 pistons do not have a dome therefore in reality the piston crown volume would be less in the calcs).
Reading posts on the forum I was lead to believe that a GTI6 Chamber volume was the same as a XU7 and the pistons rise flush with the block at tdc. I am swaying to the conclusion that the pistons are not flush with the block at tdc.
I roughly measured a spare GTI6 head I have, although I am unsure whether it has been skimmed ,it had a chamber volume of 38ish cc so that stacks up.
Might be being thick but wouldn't be the first time!
the RS pistons come flush but have a concave top, J4R have a pronounced circular dish (much like the XU7) and 10.4-1
RS gasket is 1.2mm.
Edited by welshpug
