luke1987
Xu10J2Te Coil Pins
luke1987
Hi guys does anybody know the pin outs for the above mentioned coil had a search and found them for the xu7 are they the same? Needing the info so i can get the dta loom made. Cheers guys.
Vili
This might help http://competitionsy...4-BAE_700AK.pdf
edit: Actually it wouldn't. I suppose you have the wasted spark coil? There are wiring instructions for it in the dta wiring manual.
Edited by Vili
[L'e$kro]
Source: JSO
I guess the DTA ECU can drive the coil-pack (1135) directly, so you don't need the BOSCH MTR04 ignition amplifier (1105).
The coilpack is triggered by the ground on its 2 yellow wires 112b and 112c, on pins 1 and 2 of the coil-pack.
Nico
Edited by [L'e$kro]
