John_B
Heater Resistor- What's This Bit?
John_B
My heater stopped working completely and I found it was the resistor again. I've cleaned up the disc in the pic above and it sort of works but moving the disc about greatly varies the speed of the fan.
My question is what does this disc do? I assume I can't fill the hole up with solder otherwise there wouldn't be this whole setup in the first place?
Also, does anyone still sell them new apart from Pug? GSF and ECP don't seem to do them.
That's the earth for the transistor, silly idea as it corrodes up over time. I tend to add a earth wire on the body, it bypass that then
John_B
Thanks Miles. So do you mean like this below or from the blob of solder to an earth on the car?
farmer
have you tried or bought a new resistor ??
John_B
If there's a simple fix I'd rather do that. Aren't they £50? I don't know if the ebay ones are any good.
You wouldn't believe how much I've spent on cars in the last 6 months!
farmer
dont worry i know what it costs yeah they are but cheaper than main dealer dealer is just over 60 and ebay is 54 or something
Edited by farmer
ORB
i grab a couple each time i go to the scrappy. Always have stock in stock.
farmer
I bought 2nd hand just had same problems though
Karl
true id buy straight from dealer for the sake of a few quid you get a guarentee and buying off ebay in my experience is a risky business im sure miles will verify this :)
That's it, Just need to think that the wire does the same thing as the leg so to speak,
Karl
i wonder why they didnt do this to start with :wacko:
John_B
Cheers Miles, I'll give that a try.
Yeah the one above is a 2nd hand one. It seems when everything is 20 years old all these parts are as bad as each other.
John_B
Worked a treat! Much better than just cleaning the contacts a bit.
Ciaran76
Would anyone have a part number for this as I want to replace mine. Thanks
EZ Tutty
Part number is 6445.90 I believe.
... btw for anyone repairing theirs, you can also bridge the earth track to the track to the left, this is how I did mine.
Edited by EZ Tutty
farmer
i think the chap that sells it on ebay is slightly cheaper than the dealer
Also see another Ebayer is selling an afer market resistor for 30 quid anybody used him?
Edited by farmer
Ciaran76
Thanks EZ
