mrfirepro
Block...is This Knackered
mrfirepro
Started preparing by block for the rebuild, when I removed liner 4 this is what I found.
I think it is new block time, but just wanted to check opinion of the experienced amongst you.
This is what I found
http://s1238.photobucket.com/user/mrfirepro/media/205%20projects/P1020963_666x500.jpeg.html
so decided to clean it up a bit to see if it was perforated.
http://s1238.photobucket.com/user/mrfirepro/media/205%20projects/P1020970_666x500.jpeg.html
It has not eaten all the way through, but can not have much left to go until it is through, Also note to the right the liner landing is mostly corroded away.
So what do you think??
Yep that is beyond eco repair, Time for a new block, Good thing is there's plenty out there
mrfirepro
Will keep an eye on Ebay & place a wanted add here, is there anywhere else I should try.
I also noted on the head, when I took the cam off there was a hole formed by wear (unless it was meant to be there) just behind the oil seal, is this normal.
Slo
yes its actually an oil drain hole, its so oil leaking through the end bearing doesnt build up and push the seal out.
mrfirepro
Thanks, so only a new block, a bit of good news for a change.
timoth123
Feel for you there paul.
Just found out all of my liners are knackered. So I know that disheartened feeling when something doesn't go to plan!
Keep at it mate!
ginger205
There one on EBay I saw the other day, not going to break the bank compared to the "rare" one that's on their! http://bit.ly/KQxPzR
There even!
mrfirepro
Thanks will keep that in mind
I've got one coming from a guy in N Wales, just hope it's OK
