jorg
Info On Jenvey Setup Please
jorg
Hi
Its now time for me to properly sort out my throttle bodes and i could do with some help if possible please. I am using Jenvey 45's on a Satchell Inlet and will be running 8 injectors.
Sandy recommended using the PQ2 quadrant lever instead of the linkage kit and as it saved me £80 i took his advice on board :) now the problem is what i have fitted at the moment just doesn't look right to me (will add a picture later) and I can't work it out.
Does anyone have a picture of the PQ2 quadrant actually fitted? I have looked through all the threads on the forum linked to the PQ2 and there are no pictures of it :(
Also can anyone give me some inspiration regards sorting out a throttle stop please. Totally useless with stuff like this!
any help people can provide will be appreciated
thanks for looking
Geoff
All you need is a cable stop, piece of angle between the two mounting bolts with a hole for the outer cable.
have a look on Dcc's project thread should be a picture there, works very nicely
jorg
Cheers Mei, will have a look through his project thread now :)
Hi Andrei, I have just had a look at that link you posted but the pictures and instructions are for the CLS1 linkage are they not?
This is what was sent to me from Jenvey when I ordered my bodies with the PQ2 lever:
4B0CADF7-5142-4289-816C-343CFB49683D_zps
A27C878D-9C99-4721-8822-E3612B3A5918_zps
Is the lever on the other side wrong? (too short)
johniban
Did you sort this in the end ?
