simon neil
Engine Choice
simon neil
Hi Guys looking for a bit of advice. Not sure of best engine choice. Mi 16, later Mi 16 with cast block or Gti 6. does the gti6 have a cast iron block. You seen to be able to pick up later mi,s alot cheaper. i am looking for an engine i can build to put out about 190 to 200 bhp. I would like to run on carbs as I have some dellortto,s allready. The car would be used for track days and eventually tarmac stage rally.
what you think.
thanks
allanallen
They're all cast blocks, the 1900mi is ally, the later and the 6 are cast iron. All have there merits, I recommend you do a search as there's loads of threads on the topic.
I'd personally not bother with the dellortos.
simon neil
thanks for that. what would be your prefernce . bearing in mind that this would be a budget build.
allanallen
I'd look out for a know good engine (any of them) coming up for sale if you're on a budget.
A good engine on standard management with a short ratio box and plated LSD would be the way I'd go rather than chasing bhp figures.
dcc
What's the purpose of the Car?
Don't forget - 16v's are for pussays.
Where in Bridgend you from Simon?
simon neil
litchard just down from sainsburys
simon neil
medium to longer term I would love to get it msa log booked and do the odd tarmac stage event.
allanallen
Where's the 'don't like' button??!! :P
allye
Does that mean 24v's are for men?
rallyeash
No, even bigger pussays
XU10J4 - all the benefits of the earlier XU9J4 head with full floating, oil jet cooled 2L bottom end. They make 190-200hp easily. As Allanallen said, don't overlook the importance of the LSD and shorter gearing first however.
Other than the fact they're all knackered now !
Probably correct, but they're cheap and easy to recondition.
Pistons arent so cheap up here, how much are they down under?
Around $750.
Hmm, £420 direct conversion, shame about all the import duties etc taking them nearer the price of decent forged pistons.
These are locally machined from Mahle blanks.
