fliprio
Problems Doing The Crankshaft Pulley Bolt Up
fliprio
im trying to do the crankshaft pulley bolt back up, it came off with the windy gun quite easily but I cant stope the crank from turning when doing it up
Haynes tells me to put it in 4th and have someone put their foot on the brake, but this doesn't work, with a decent length torque wrench it just turns!
Any tips?
push harder on the pedal, or jam the flywheel with a screwdriver.
fliprio
its not trying to move the car, it actually turns quite freely like it isn't even in gear, but if you try and rock the car it seems to be in gear which is a bit perplexing
where can you get a srew driver in the flywheel? im loathed to stick it in the timing pin hole in fear of it snapping/jaming
Kane
You can see a little portion of the flywheel at the top OS of the engine near the starter motor. Get the largest flat headed screw driver in there then tighten up, easy :)
fliprio
I managed to do it via the small pull off cover at the front near the timing hole, luckily the screwdriver kept it still to torque it up, so much grease and much on this engine its a nightmare to find all the little access holes!
All back together and starts now which is good
Kane
Sorry I just realised I put offside instead of nearside there, my mistake. Glad you've got it sorted anyway
