erbs 42 1 Cars Posted May 1, 2015 i have misplaced my stereo code that was on a credit card sized bit of plastic i have the serial number which is 0173694, would this be any use to find the code? Share this post Link to post Share on other sites
erbs 42 1 Cars Posted May 1, 2015 can anyone help me here? Share this post Link to post Share on other sites
Kane 34 Posted May 1, 2015 Not sure whether the serial number will help or not but I think I remember seeing someone on here hook up the radio to a battery at home and manually go through the combinations one by one until they unlocked it. Share this post Link to post Share on other sites
mrfirepro 127 1 Cars Posted May 1, 2015 (edited) Jamie, If it's the standard Clarion, they are coded by solder joints on the main board. Depending on how handy you are with a soldering iron you can put a different code in. If you want to have a go at it http://forum.205gtidrivers.com/index.php?showtopic=153104&page=14 post number 266 will help Let me know if you want any more help. I also think there are others that can get the code from the solder joints but I've never been able to figure it out. Just like to add this worked for me but I don't know if anyone else has given it a try. Have also since discovered that they all link to a common rail so your soldering does not have to be that accurate between links. Edited May 1, 2015 by mrfirepro 1 Share this post Link to post Share on other sites
stumpyjag 6 Posted May 2, 2015 I did all mine with the soldering method and they all work fine. Share this post Link to post Share on other sites
gizzmo 3 1 Cars Posted May 2, 2015 I am sure some one here can decode the stereo serial number, think it may be anthony Share this post Link to post Share on other sites
erbs 42 1 Cars Posted May 3, 2015 at the moment the radio is stuck,i tapped in what i thought was the right numbers and now its froze, i cannot clear the numbers, i pressed all the buttons and even disconnected from the car and powered it up and still stuck with the numbers i typed in don't know whats going on now Share this post Link to post Share on other sites
Clarky3rdNut 13 Posted May 3, 2015 I think you have to press the 'Band' button for up to 5 seconds after entering the code. Share this post Link to post Share on other sites
erbs 42 1 Cars Posted May 7, 2015 Ok so the stereo is still without a code, is there anyway of finding the code without having to spend hours dialling in numbers? Share this post Link to post Share on other sites
Tom Fenton 1,526 Posted May 7, 2015 Just find somewhere local that can decode. Last one I had done was £15. Share this post Link to post Share on other sites
Clarky3rdNut 13 Posted May 7, 2015 Cracking the code really isn't as daunting as it sounds. 1.5 hours max. Remember there are no zeros and only five numbers. 1111, 1112 ... 1115, 1121, 1122 etc. Share this post Link to post Share on other sites
erbs 42 1 Cars Posted May 7, 2015 all i remember is that it started with a 5 so less faffing about i would imagine Share this post Link to post Share on other sites
erbs 42 1 Cars Posted May 10, 2015 ok found it, when it was advertised the code was in the pic and i found it on the net such an easy number too 5222 is the code, how did i forget this? Share this post Link to post Share on other sites
Telf 222 2 Cars Posted October 2, 2016 unbelieveable! I disconnected the battery and couldn't remember the code!!!!!!!!!!!!! So its 2454 for future reference! Share this post Link to post Share on other sites
rhysmoore 0 Posted May 17, 2018 Hi Guys, my clarion recently stopped working and seems to need unlocked. How do I go about trying these codes? Is there a particular way to input them? Share this post Link to post Share on other sites
