Dar_Reynolds
Correct Size Weber Jets For Euro Rallye
Dar_Reynolds
Can anyone tell me what size jets I should have in my Twin 40's on a Euro Rallye? Standard 1.3 set up
I think the ones in mine are too large :/
Darren
Wallby
There are a few different jet sizes that came in different years, the ones I know of are;
Idle 58F9 or 62F21 (Im running 65F8 which works well)
Main jet 138 or 145
F68 Emulsion tube
190 Air corrector
What does yours have in now?
Dar_Reynolds
​Sorry for the delay in replying and thanks for the info :)
​I've got 60f21 Idle 142 Mains 190 Air
​I've discovered that 2 'O' rings had perished on the idle jets, replaced these and it was better but still not great under 3500rpm
I have now also found that one of the accelerator pump jets isn't working, hoping to get it all back together on Friday when I'm also hoping (fingers crossed) to at last have it UK registered
Dar_Reynolds
One more thing :/
The Hungarian guy I bought the car from, told me it isn't set up to run unleaded, I'm wondering if he thought this as it was running so badly (therefor using lead replacement
additive).
Any thoughts on if I need to carry on with the additive?
aldworth33
Just get the timing set up properly to run unleaded 95ron, my old man's 205 had to get the ignition timing adjusted back in the day to run unleaded when lrp was being phased out
Wallby
Make sure the pump jets are adjusted the same on the long screw underneath, otherwise you'll get them spraying at different times.
205Rallee
Having had my TU24 from the times of leaded petrol until now, I've always run on leaded and now Super Unleaded, the very few times I've run it on normal unleaded have been emergencies when I couldn't get super and it runs like a pig. It only runs well on Shell V Power or Tesco Momentum.
Best bet is to get it to a rolling road.
