artois7
Arch Trim Clips / Grommets On A Budget...
artois7
Hi all,
Trying to refit my arch trims without spending £25 per side on the "kit" on ebay...
I reckon this can be done cheaper. I found the starlock washers:
http://www.ebay.co.uk/itm/1263-EMBLEM-CLIPS-PUSH-ON-FIXING-6-MM-205-309-405-XANTIA-205-GTI-405-MI16-x15-/321591075103?hash=item4ae052611f:g:YykAAOSwg3FUbGV0
Now I just need to locate the rubber bushes / grommets that go through the wing, and the rubber spacers that sit between the wing and the washers. I have all the existing white clips to go into the washers.
Anyone got any advice on the bushes/grommets and spacers? the wing holes are 8mm allegedly so this may work (the 9.5mm x 6.4mm is close ish):
http://www.ebay.co.uk/itm/Rubber-Wiring-Grommets-Cable-Wire-Open-Hole-Ring-Electrical-Automotive-/270936644005?var=&hash=item3f151519a5:m:mlzYNrxqcy6T1iWLfqDHMqg
artois7
Found the thread on here suggesting nylon bolts, washers & nuts. Great idea. 10 delivered for £2.49 and will make removing them in the future super easy.
