idoari
Proper Engine Clearences
idoari
Hi,
i have the haynes manual but i can't find anywhere the proper spec for the following clearances to use plastigauge on:
*cam to cap clearence (the cap that clamp the cam to the head)
*crank to main journel clearence (the ones clamping the crank to the block)
*crank to connecting rod clearence
can anyone tell me what it's needs to be?
*all the clearances are with the "half moon" bearing installed in the caps.
thanks
Ido
mhyphenl
they are in the haynes workshop manual. At the beginning of the chapter for your engine! It gives all the tolerances you need, don't think there's one for the cam bearings as they're not replaceable.
idoari
i have the workshop manual but i can't see it...
Edited by idoari
That's not a workshop manual I think
idoari
it is , believe me
Edited by idoari
Mains is in mine (page 2D-3), but you need to read carefully to work out the rods.
0.002"-0.0025" is what I use on the rods. Cam is less critical.
Edited by petert
idoari
in which page it is ? i can't find the paragraph you quoted.
It doesn't have page numbers. It's a PDF I found somewhere. Chapter 2, page 3, I guess. I think the 405 manual has a lot more detail if you can find one.
p61/233
Edited by petert
idoari
what is the piston rings gap (when you gap them with a feeler gauge inside the bore) on XU5JA engine (1.6 115hp) 1990 ?
mrfirepro
My manual states piston ring end gaps of 0.3 to 0.5mm
top 0.013"
2nd 0.016"
from memory
