allye
Footwell Leek? This Might Be The Source.
allye
Thought I'd just chuck this up as a point for people to check if they can't sort a footwell leak.
This is a wing off job,
Under the hole where the scuttle drains there is a panel overlap covered in seam sealer, mine was slightly separated which explained why it took a little while for it to make its way into my driver footwell.
This photo is with sealer removed and you see the surface rust where it was entering.
Derusted, primed and seam sealer reapplied, all good now after a hard down pour.
Hope it helps?
Telf
nice one allye, looks like I will have to do the same
