Neil205 1 Posted June 27, 2016 So good news after replacing quite few parts finally passed its MOT with no advisories , 1.6 , 1990 .. When driving the car , when slowing down to a junction or roundabout and changing down gear the engine Stop light comes on and engine is stalling , it starts again straight away , Ideas ? I have adjusted the AFM and air idle screw , the AFM is turned right in , as car before was kangaring a lot before and cutting out before could drive it . The other issue is a knocking noise when reversing , seems to come from offside front area ? This also combines when coming to a standstill in forward a slight grinding noise , all brakes and pads hav been replaced . Could it be driveshaft ? Share this post Link to post Share on other sites
j_turnell 134 3 Cars Posted June 27, 2016 Check your throttle position sensor clicks just as you open the throttle. What was your CO and hydrocarbons on the MOT? The knocking noise will more than likely be worn sliders on the calipers, assuming it's running standard bendix calipers, it's a common problem. Share this post Link to post Share on other sites
Neil205 1 Posted June 28, 2016 Ok I'll check that , the CO level on mot was 3.76% but they adjusted it down to 2.08% but since I have increased more as the car wasn't running right , hence now the AFM screw is fully turned it ? Do I need to reset again following adjustment settings ? Yes standard bendix Callipers , where can I pick up new sliders then ? Thanks Share this post Link to post Share on other sites
Anthony 1,000 Posted June 28, 2016 Idle mixture is too rich which will cause the engine to hunt and stall. You need to aim for 1-1.5% CO max. Screwing the mixture screw inwards richens the idle mixture, so you've richened something that was already too rich! Share this post Link to post Share on other sites
