marcy
Mi16 Knock Sensor Bolt
marcy
Hi i have an alloy block mi16 does anyone know what bolt i need for the knock sensor, i know to replace the centre main bearing cap bolt with a double ended bolt but having trouble identifying the right bolt the two part numbers from service box are
0132 32
0132 34
however i cannot tell the difference
and washer 0133 12
any help would be great thanks
marc
I have a few if you can't locate one locally.
marcy
Hi that would be great how much are you wanting for out with postage thanks
It needs to stop raining so I can get to the shed! I'm hoping I can send it as a letter, otherwise postage is expensive.
Edited by petert
marcy
That would be great I don't suppose you would have the rotor arm adaptor that goes on the cam as well that you would be willing to sell. Hopefully when I get it up and running will be contacting you about an inlet cam
Thanks for your help
Marc
