calvinhorse
Ford Group A Studs - Peugeot Wheels
calvinhorse
My pug is running ford group A wheel studs (thread pitch 12x1.5) for winter I want to put standard peugeot alloys on, does anyone know of a flat seated nut in 12x1.5 that will work with a peugeot alloy?
Grayston?
conversion washers-
Look at this on eBay http://www.ebay.co.uk/itm/301895769845
direct fit toyota nuts, large closed head so might not work, not sure on shank diameter either
Look at this on eBay http://www.ebay.co.uk/itm/120934545503
or these for the later type pug alloys for the flat seat bolt which has a taper under the head for the steel spare wheel, you could drill your wheels out and press these in so they're not loose.
Look at this on eBay http://www.ebay.co.uk/itm/361509467645
see here
calvinhorse
conversion washers-
Cheers WP, I did look into doing it like this but it got very pricey buying ford - aftermarket nuts then the washers, those washers are cheap compared to most I've seen
PeterT I never knew they existed, that might just answer my question
