GLPoomobile 958 Posted February 27, 2017 Hello trusted and knowledgeable car geeks I want to buy some number plate adhesive tape but have no idea what to buy. Everything I've looked at gets variably reviews, with some saying it's the stickiest thing ever and some saying it's rubbish. But it's always tricky to trust the opinions of strangers (potential morons), whereas I always know I'll get sensible feedback on here So does anyone have a product they've used and can recommend? Or, is adhesive tape just a total waste of time? There are other options I'm considering, but would prefer the clean uncluttered look. This is for pressed aluminium plates, and the front one will have a very slight curve. Share this post Link to post Share on other sites
Anthony 1,000 Posted February 27, 2017 Probably not much help, but I've always just used some generic unbranded stuff from eBay and providing that the bits were clean and degreased, there was no way that they were going to come off again without a fair bit of effort. The proviso there is that the plate is firmly stuck all around - I don't think that it would work on something like a 205 front number plate where it's only in contact with the bumper on the upper edge and the air pressing against the lower edge of the plate. Share this post Link to post Share on other sites
GLPoomobile 958 Posted February 27, 2017 That's what I was thinking Anthony, that a lot of people who give bad reviews just don't know how to, or haven't, prepped their surfaces correctly. I have had cheap foam double sided tape (for other purposes, not number plates) that's been rubbish though, and after a year or so any that's left on the roll has just dried up a bit and has 0 adhesive quality to it any more. For the front one there will be a bit of a gap where it overlaps the air intake, but not as bad as on a 205. More like 2/3 stuck at worst, or maybe 3/4 stuck. I suppose I could (though it's just more complication) make some small L shaped brackets that I could screw inside the air intake just to butt up behind the unstuck portion of the plate. Or I could Tigerseal the bugger on Share this post Link to post Share on other sites
welshpug 1,621 Posted February 27, 2017 anything wrong with a pair of number plate screws? Share this post Link to post Share on other sites
Rock Lobster 28 Posted February 27, 2017 I have used the ones from halfords on 4 of my cars now and had no problems at all, they do it in a couple of thicknesses depending on the shape of your bumper etc. Like you say, half the battle is in the prep, if you clean and degrease the surface well enough then you shouldn't have any problems. Share this post Link to post Share on other sites
Henry Yorke 269 3 Cars Posted February 27, 2017 Get a wide sticky pad with foam between the surfaces, so it will not shake off. I use brake cleaner on both surfaces before application and a firm press. Thin width tape has more chance of water getting in at the edges and it coming unstuck. Share this post Link to post Share on other sites
steve@cornwall 100 Posted February 27, 2017 Stick some tigerseal in there as well, using the pads to keep it in position whilst the tiger seal cures. Won't be going anywhere then! Share this post Link to post Share on other sites
barneys66 120 1 Cars Posted February 27, 2017 Cleanliness is next to Godliness. I've got loads at the workshop and it's never let me down (and took some removing when required) - pm me your address and I'll send you some. In fact I think one of my quarter badges is held on with it, and the metal fender emblems on my truck! May have to wait until next weekend to fetch it though, so no use if in a hurry.. Share this post Link to post Share on other sites
Tom Fenton 1,524 Posted February 27, 2017 I bought some from the local factors, it was bloody awful, paper backed foam tape. In the end bought a roll from Halfords of all places which is much better. Share this post Link to post Share on other sites
gmyorks 2 1 Cars Posted February 27, 2017 ive used some double sided sticky foam you can get from a upvc double glazing shop, thats on the rear plate. Share this post Link to post Share on other sites
iPlod999 143 1 Cars Posted February 27, 2017 Bathroom sealant. Share this post Link to post Share on other sites
GLPoomobile 958 Posted February 27, 2017 Cleanliness is next to Godliness. I've got loads at the workshop and it's never let me down (and took some removing when required) - pm me your address and I'll send you some. In fact I think one of my quarter badges is held on with it, and the metal fender emblems on my truck! May have to wait until next weekend to fetch it though, so no use if in a hurry.. Really?! Wow, thanks man, that is great :-) Absolutely no hurry at all. Will PM you later. Cheers Share this post Link to post Share on other sites
barneys66 120 1 Cars Posted February 27, 2017 Really?! Wow, thanks man, that is great :-) Absolutely no hurry at all. Will PM you later. Cheers Anytime - us Barnabys have to stick together.. Share this post Link to post Share on other sites
GLPoomobile 958 Posted February 27, 2017 Anytime - us Barnabys have to stick together.. Ahhhh, I see what you did there - stick together - very good I guess I best not tell you it's not my real name. Shocker I know! Share this post Link to post Share on other sites
GLPoomobile 958 Posted February 27, 2017 anything wrong with a pair of number plate screws? would prefer the clean uncluttered look. This is for pressed aluminium plates, and the front one will have a very slight curve. I chose pressed aluminium plates over standard plates because I'm being a bit of a tart. Therefore I don't want to lose tart points by having ugly plastic screw caps in there. Share this post Link to post Share on other sites
barneys66 120 1 Cars Posted February 28, 2017 I guess I best not tell you it's not my real name. Shocker I know! Argggh - the deception !! Share this post Link to post Share on other sites
