Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Gti6 Caliper Piston Seal Size.
  • Please log in to reply
7 replies to this topic
#1
JamPug
JamPug
  • Drivers
  • 85 posts
  • Name:James
So I'm rebuilding my gti6 calipers and I've hit a bit of a roadblock.
I'm tried inserting the piston back into the cylinder with a new seal but the seal looks far to small. I broke one while trying to insert it. I understand it's meant to be a tight fit but seal doesnt even sit in the groove tightly. Any thoughts?
Also does anyone know where I can buy those seals individually ?
#2
  • Pitcrew+
  • 30,090 posts
  • Name:Mei
piston is 57mm
#3
  • Pitcrew
  • 5,627 posts
  • Name:Peter Taylor
Maybe they are seals from the smaller 306 brakes? 266mm rotors, 52mm?
#4
JamPug
JamPug
  • Drivers
  • 85 posts
  • Name:James
I measured ID of the seal and its approx 52mm so I think you guys might be right. Thanks 😊
Best get a new seal kit order ahhhhh
One last question..... what size bolts do I need to bolt he carriers to my hubs ?
Edited by JamPug, 12 May 2017 - 06:44 AM.
#5
  • Team Managers
  • 18,775 posts
Garage View Garage
Same bolts most Lucas/Girling calipers (e.g 1.9 GTi) use on 205's. 306's etc - they're much shorter than the Bendix calipers ones you've probably removed.
As said, GTi-6 are 57mm pistons and are the only 306 brakes of that size. I suspect you've been given the more common 54mm piston kit as used on most of the 266mm brake applications (306 XSi, HDi, S16 etc).
From what I can see on Servicebox, the OE part number for the GTi-6 caliper seal kit is 4448.79 if you want to cross-reference against that. It's quite expensive from Peugeot though at £30.72 inc VAT, presumably per side.
#6
  • Pitcrew
  • 5,627 posts
  • Name:Peter Taylor
Careful. Some 306 caliper bolts are M12x1.25, not M12x1.5 like a 205.
#7
PhilNW
PhilNW
  • Drivers
  • 183 posts
  • Name:Phil
Try brakes international
#8
JamPug
JamPug
  • Drivers
  • 85 posts
  • Name:James
Little update
I bought a kit it was the wrong size
Bought another kit
Fitted one side
Broke the other side
Bought another kit for one side (different brand)
That was the wrong size
Returned that
I rang the second company, they agreed to replace the dust seal, that I broke free of charge.
Big shoutout to biggred !
