Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Adjusting Brake Booster?
  • Please log in to reply
3 replies to this topic
#1
B1ack_Mi16
B1ack_Mi16
  • Pitcrew+
  • 2,780 posts
Is there any form of adjustment on these?
Possible to turn the rod in/out to make it give some more assistance etc.?
I'm very disappointed over the brakes on the T16. 23mm MC, 235mm brake booster diameter etc.
Coupe brembos on it 305mm discs etc.
#2
  • Pitcrew+
  • 30,090 posts
  • Name:Mei
no, assistance is purely from the vacuum, the adjustment is to take up any free play before the servo starts pushing on the master cylinder.
do you still have the vacuum pump fitted?
#3
B1ack_Mi16
B1ack_Mi16
  • Pitcrew+
  • 2,780 posts
No, 2.0 Mi16 / T16 don't use vac pump afaik, only the 306 S16.
But I'm looking into getting a 306 S16 inlet cam now and try to fit the pump to get some more vacum at least. But anyway the brakes are really under-servoed.
Maybe I need to put a 5008 booster there. Is the newer cars boosters twin or triple chamber units since the pedal effort is so small?
#4
B1ack_Mi16
B1ack_Mi16
  • Pitcrew+
  • 2,780 posts
I notice the T16 and 5008 boosters both are 255mm actually.
Does the newer cars use some extra pressure boosting utilizing valves in the ABS unit?
