Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Timing Belt Crank Seal
  • Please log in to reply
2 replies to this topic
#1
toolie72
toolie72
  • Drivers
  • 437 posts
  • Name:Paul
Garage View Garage
Anybody had issues with febi crank seals (timing end)?
Got one of Ebay to sort a weeping seal-result- got me a gusher!!!
Bought one today from local factors and its tighter (both say 42 mm) but a lot deeper as well
Waiting for new belt as it shat oil all over the other one
Pants
#2
Thijs_Rallye
Thijs_Rallye
  • Drivers
  • 67 posts
  • Name:Thijs Vanlier
Garage View Garage
Seals and gaskets I only use Victor Reinz, Elring or Goetze.
Seals have a rotation direction, so if you've only looked at the size this could be a reason for leaking, although it shouldn't be gushing. Also in some cases the oilpump drive sprocket has a worn surface which doesn't help either, when assembling watch that you aim the sealing lip on a fresh part.
#3
toolie72
toolie72
  • Drivers
  • 437 posts
  • Name:Paul
Garage View Garage
Fitted second seal tonight, new belt etc and fired her up
No leak
Second seal did however have a rotation arrow on it and a far beefier (if that’s the word) scroll to it
