309PUG
Crank Wheel
309PUG
Hi,
Two questions really:-
This is for people with XU 8v engines.
1. How do you fit the multi toothed wheel to the crank, do you simply rely on the clamping pressure from the crankshaft bolt/thick washer ? or some sort of dowel / pin ??? what has eveyone else done.
2. Can someone in 'simplistic' terms describe exactly how and where the missing tooth is positioned when mounted, and is this a critical position or is it +/- a couple of mm ??
Chris
mfield
The wheel ive got is located by a small key, it protrudes into crank cut out. then the pulley is bolted back on top.
On mine the missing tooth is 9 teeth on from the sensor at tdc. The sensor sits in the middle of the 9 tooth. Its not critical because the sensor is on a sliding bracket for getting the timing spot on. When moved about 5mm either way it makes about 5 degrees, if you think that the gap between each tooth is 10 degress.
309PUG
Thanks,
You say your sensor sits in sliding bracket, where did you get that from ??
Chris
mfield
Webcon with the alpha kit, can be bought seperate let me know if you want the part no.
Here is a picture:
Edit: here's the trigger wheel aswell
Edited by mfield
309PUG
thanks for the pics.
Assuming the key way on the crank is in the same position on all 8v's then your photo is a good guide where the cut out key slot needs to be in relation to the missing tooth ??
PS part no. for the sensor bracket would help please.
Chris
Edited by 309PUG
mfield
pt. no.'s
trigger disc: 9990291600
sensor mounting adapter bracket: 9990293600
bolts m7 x 50mm: 9990282900
bracket spacer: 9990296200
trigger disc keyway boss: 9990282200
sensor mounting bracket: 9990154600
screws m5: 646902200
nyloc nut m6: 9990006400
plain washer 6mm: 9900030400
All the above items are in the crankshaft trigger disc kit pt. no. : 9990295700
engine speed sensor: wss077
hope that's of use :blink:
Mad Professor
Any pic's of it all fitted?
mfield
abit late now, i took them pictures on monday B)
309PUG
Many thanks Mfield.
Chris
One final question, looking from that list the keyway boss is seperate from the wheel, how are these two locked / held together ??
mfield
here you go :)
and
Because of a mis-spent youth my memory is very bad and have just realised that the trigger wheel actually bolts down on top of the alternator pulley, not the other way round B)
309PUG
Sorry to be a pain in the bum, but it looks to me as if the boss and crank wheel are keyway'd together and collectively only rely on clamping pressure from the crank bolt and thick washer. In other words the boss is un necessary so long as the cranckwheel is of the correct diameter to fit on crank shaft. Do you aggree ??
Chris
Ryan
I thought the idea was that the boss replaces the thick washer on the end of the crank?
mfield
Hopefully i can show this clear enough and explain what the score is :o
Here is a picture of the bottom pully, if you look to the left you can see the two bolt holes where the senor bracket attaches.
This next picture shows that there is a recess from the face of the pulley to the end of the crank. The boss and key go through the trigger wheel and sit in this recess.
J6D8cVnfml
After locating the boss and key in the recess the pulley bolt is refitted
Sorry i cant show you the wheel on the pulley but they are 80miles apart.
Once again sorry for the quality of picture :D
Mark
Edited by mfield
mfield
Should also add that the boss, key and wheel are all tight as hell to fit together ( hammer job :ph34r: )
Mad Professor
Where did you say you can order thease parts from?
Do you have a url and or number for them?
309PUG
Thanks Mark, I fully understand now, got there in the end. B)
mfield
Webcon B)
http://www.webcon.co.uk/
just have to contact them and quote the pt. no. for the bits you want or the pt. no. for the kit, i have no idea of costs.
that's ok :)
Edited by mfield
Mad Professor
Thanks.
Just found this Price list on there site. Webcon December 05 Retail Price List(GBP)
9990291600 - TRIGGER DISC 36-1 PE - £85.00
9990293600 - Not Found
9990282900 - Not Found
9990296200 - SPACER MODIFIED 7.5M - £1.29
9990282200 - KEYWAY & BOSS(PEUGEO - £33.82
9990154600 - RPM SENSOR BRACKET - £9.90
646902200 - Not Found
9990006400 - NUT M6 NYLOC DIN 985 - £0.52
9900030400 - Not Found
9990295700 - ALPHA CRANK SENSOR K - £97.75
WSS077 - SENSOR ENG SPEED SEN - £24.95
mfield
bit pricey !!!
