skeggyrik
Xu10 And Xu9 Oil Pump Inter-changability
skeggyrik
Is the Xu 10 oil pump a direct swap for the 1.9 Mi16 Xu9 item? I've not seen them.
I ask as I understand only the Xu10 pump has the provision for attaching the chain guard via the 2 M6 screws?
I will be going the Gti-6 (Xu10) sump, drive sprocket (26 tooth) and chain (52 link) route and wanted to fit the chain guard also but this requires the Xu10 oil pump to be fitted.
Rich
That's correct. XU10 pumps are otherwise identical except for the two extra M6 mounting holes.
skeggyrik
Thanks Peter, I will be contacting you in the not too distant future to get an extended pickup sorted to make the above worth while.
Not all XU10 pump's have the bolt holes so just be careful is buying a S/H one
DrSarty
I have an S16 block for my project and:
i) will be needing a suitable oil pump and gubbings v soon if anyone can help?
ii) will be in touch with PeteT too ref buying his sump and extended pick-up anti-surge modification
Nice and useful thread. Cheers
Rich :(
