Quigs 1 Posted June 3, 2007 hi all, i have a 2lt turbo 205, i was just wondering how i can get the fev counter to work?? any ideas, done a quick search but get online for long. cheers quigs Share this post Link to post Share on other sites
Quigs 1 Posted June 3, 2007 another quick question is where would the vss senor be on my 205 turbo?? Quigs Share this post Link to post Share on other sites
Baz 421 Posted June 3, 2007 The gearbox between it and the speedo cable afaik. there's a very similar thread around atm. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted June 4, 2007 Rev counter is signalled from the ecu so you need a convertor or to modify your clocks with a suitable rev counter. Modified clocks topic Graham. Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted June 4, 2007 pugtorque said: Rev counter is signalled from the ecu so you need a convertor or to modify your clocks with a suitable rev counter. Modified clocks topic Graham. Or you could just use Hilgert's method and use 2 diodes and 1 resistor, and get signal from output side of the ignition modules. Works like a charm, have done it on a 309 with S16 engine myself. Share this post Link to post Share on other sites
Quigs 1 Posted June 4, 2007 BazGTMi said: The gearbox between it and the speedo cable afaik. there's a very similar thread around atm. ah right i don't remember doing anything else down by the speedo cable does it go in to the gearbox, another words i aint got a clue. B1ack_Mi16 said: Or you could just use Hilgert's method and use 2 diodes and 1 resistor, and get signal from output side of the ignition modules. Works like a charm, have done it on a 309 with S16 engine myself. do you know it is done, would be very helpful if you could tell me, cheers Quigs Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted June 4, 2007 Quigs said: do you know it is done, would be very helpful if you could tell me,Possibly the same way as shown in this attachment. Graham. Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted June 4, 2007 yes Graham, exactly the same. Share this post Link to post Share on other sites
sonofsam 5 Posted June 4, 2007 (edited) Yep, this is what I have planned too, already have the diode pack built. Any reason why I cant take a signal from the negatives on the ignition amp module?! Cant gain enough access at the coil pack plug at the moment Edited June 4, 2007 by sonofsam Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted June 4, 2007 sonofsam said: Yep, this is what I have planned too, already have the diode pack built.Any reason why I cant take a signal from the negatives on the ignition amp module?! Cant gain enough access at the coil pack plug at the moment As long as you take it from the wire going from ignition module(s) to the coil(s) it's just fine. Share this post Link to post Share on other sites
sonofsam 5 Posted June 4, 2007 Quigs said: ah right i don't remember doing anything else down by the speedo cable does it go in to the gearbox, another words i aint got a clue.cheers Quigs Quigs, this is a VSS, looks like a regular speedo cable drive, but has a three pin connection for a plug on the turbo loom. Should be 17 theeth IIRC on the red cog you see in the picture, otherwise your speedo may read 'out' B1ack_Mi16 said: As long as you take it from the wire going from ignition module(s) to the coil(s) it's just fine. Thanks Kristian, will have a go at this then. Share this post Link to post Share on other sites
Quigs 1 Posted June 4, 2007 cheers all, i'll give that a go. would of the vss been on the xm gear box then?? if so have to if it's still where i left it Quigs Share this post Link to post Share on other sites
petert 611 Posted June 4, 2007 Quigs said: i have a 2lt turbo 205, i was just wondering how i can get the fev counter to work?? Don't forget that even after you've made the diode pack you still need to modify the rev counter to accept the low voltage signal. Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted June 4, 2007 petert said: Don't forget that even after you've made the diode pack you still need to modify the rev counter to accept the low voltage signal. Didn't have to modify anything on mine, which I just wired into the coil-driver outputs from the Emerald, neither on my mates 309 which we put the 2.0 S16 engine into. On the S16 we needed 4 diodes though as It's 4 coils. Wired it up to the output wires from the ignitionmodules and everything worked fine. Share this post Link to post Share on other sites
petert 611 Posted June 4, 2007 (edited) That's odd for a 205. They have a large value resistor on the tacho input which attenuates the high voltage input from the standard coil. It must be marginal whether it works or not as standard. It certainly works perfectly when you short out the resistor. 405 tachos are different. They work perfectly off a 12V input. Edited June 4, 2007 by petert Share this post Link to post Share on other sites
Ant 2 Posted June 5, 2007 sonofsam said: Quigs, this is a VSS, looks like a regular speedo cable drive, but has a three pin connection for a plug on the turbo loom. Should be 17 theeth IIRC on the red cog you see in the picture, otherwise your speedo may read 'out' Thanks Kristian, will have a go at this then. Thats interesting Sam.. I used the 205 cog ( green i think ) and not the red 605 one, and my speedo is out... When it shows 50, im doing 70 !!! That was on my "to do" list in the next few weeks Thanks Share this post Link to post Share on other sites
bales 1 Posted June 5, 2007 (edited) Ant said: Thats interesting Sam.. I used the 205 cog ( green i think ) and not the red 605 one, and my speedo is out... When it shows 50, im doing 70 !!! That was on my "to do" list in the next few weeks Thanks My speedo has been reading out aswell and I think this is the reason, at 60mph mine is exactly 10mph out so mine says 50mph. Then at at an indicated 70mph I am doing 85mph!! My 205 speedo worm gear is red, and I can't remeber what colour the one off the turbo engine is, but I shall be swapping them round. Out of interest does anyone know what the rev limiter on the xu10cjte is, as erm...when I went down (a very quiet) stretch of motorway the other night, I put my foot down for a little bit to see what it pulled like and was suprised when at an indicated 110mph I shat myself as I thought I had hit a fuel cut as it suddenly cut all power It seems that this may have been ahem....the rev limiter in 5th All I can say is that it took a very very short time to get there, any estimations at what speed that may have been on a standard 1.9 box? Edited June 5, 2007 by bales Share this post Link to post Share on other sites
sonofsam 5 Posted June 5, 2007 (edited) Ant said: Thats interesting Sam.. I used the 205 cog ( green i think ) and not the red 605 one, and my speedo is out... When it shows 50, im doing 70 !!! That was on my "to do" list in the next few weeks Thanks Hi Ant. Im pretty certain I checked the number of teeth against the 205 unit, and it was the same. However I didnt get the VSS from a 605/xm/406 etc.. Edited June 5, 2007 by sonofsam Share this post Link to post Share on other sites
Mikey G 3 Posted June 6, 2007 pugtorque said: Possibly the same way as shown in this attachment. Graham. Does anybody know if you need the same values of components as shown here or are there alternatives? I can get the rectifier diodes but the zener is not listed in the likes of Maplins or RS. Share this post Link to post Share on other sites
jonnie205 1 Posted June 6, 2007 maplins etc dont do the zener listed but you can get one which is very similar and seems to work fine. I have never needed to mod the 205 tacho in order for it to work with the 4 diodes of the coil packs either Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted June 7, 2007 Actually you can leave the Zener out without problems. Share this post Link to post Share on other sites
