ady 3 Posted June 27, 2007 This might be a good idea.. i just rang peugeot and got a price on front dampers and top mounts, thought it would be usefull to others if i put them up then perhaps anyone else who gets prices can do the same? Front dampers £82 + VAT per side Front top mount kit £38 + VAT per side Ady 2 Share this post Link to post Share on other sites
nick 3 Posted June 27, 2007 Good idea. Part numbers would be good as well. Nick Share this post Link to post Share on other sites
Guest marsred Posted June 29, 2007 No part numbers unfortunately but I asked about new front fogs and they were £47.50 + vat a piece. (also got the impression the 'classic' status of the 205gti was a bit lost on the Peugeot parts chaps... surely they were all traded in for 106's years ago?!) Share this post Link to post Share on other sites
Benito 0 Posted June 30, 2007 (edited) Front Dampers = 5202 N1 (Left) & 5202 N2 (Right) Top Mount Kit = 5031 25 Fog Light = 6204 75 I got these off of my Peugeot Parts CD, but You can also find them at:- http://www.pugspares.co.uk The Guys at my local Dealer are excellent, I've bought so much stuff there over the years, that I should own shares in the place! One Guy there always checks the local Citroen garage's stock levels and prices for Me when I need parts, as some times their prices are cheaper for exactly the same part! I'd buy the Top Mount kit from Peugeot, but You can get the same genuine Dampers & Lights for cheaper if You shop about. Edited June 30, 2007 by Benito Share this post Link to post Share on other sites
Edp 67 3 Cars Posted July 1, 2007 (edited) All prices subject to the dreaded VAT 5202 N1 Left Front damper £82 5202 N2 Right Front damper £82 5031 25 Front top mount kit £38 6204 75 'Driving light' £47.50 Each 2150 A7 Clutch Cable £18.83 1303 73 Phase 2 Clear Expansion Tank £20.09 6431 42 Front Windscreen Washer Reservoir £10.18 4643 18 Brake Fluid Reservoir Cap £18.05 2403 97 Silver Gear Knob BE3 £8.89 8321 39 Rear Quarter Badge Clips 0.07p Each 8659 HK Rear Peugeot Badge £12.26 8660 48 Rear 205 Badge £6.12 8660 A1 Rear GTi Badge £5.89 Rear quarter badges, numbers for phase 1 grey colour but prices the same for phase 2 black. 8659 26 Rear Quarter GTi Badge Right £16.09 8659 98 Rear Quarter 1.9 Badge £14.12 8659 25 Rear Quarter GTi Badge Left £16.09 I reckon this is a good thing to pin at the top of the page as I will keep adding to it as I buy bits and i'm sure others will too. Moderators?? Edited July 1, 2007 by Edp Share this post Link to post Share on other sites
GWtaylor 8 1 Cars Posted July 1, 2007 As stated above Should be a STICKY then saves doing searches each and every time Share this post Link to post Share on other sites
oli-pug 6 2 Cars Posted July 2, 2007 (edited) very good idea! all prices +VAT 8v thermostat gasket - £1.46 distributor o-ring seal - £0.82 aerial lead - £7.58 1.6 gti caliper bolts - £1.18 each OSR red trim - £4.12 bodykit clips x 10 - £3.90 gear linkage subframe balljoint - £3.92 oil filter - £8.10 Edited July 2, 2007 by oli-pug Share this post Link to post Share on other sites
Ryan 99 Posted July 2, 2007 6976 06 - XU crankshaft woodruff key - £0.48 1424 R7 - 309 GTI-16 90-degree AFM hose - £22.51 0258 37 - Mi16 oil filler cap (single outlet) - £4.81 1172 99 - Mi16 1.9 dipstick - £4.90 1351 59 - S-shaped mi16 coolant hose (back of head) - £4.58 8236 E7 - Phase-2 5-hole switch trim panel - £8.23 6553 25 - Air conditioning switch - £13.23 6553 38 - Heated seat switch - £10.71 3247 03 - Driveshaft intermediate bearing - £16.05 1798 75 - Exhaust fitting bolts (kit) - £14.96 All +VAT Share this post Link to post Share on other sites
Edp 67 3 Cars Posted July 2, 2007 7583 75 Red tufted Carpet £320.04 ouch!! 5150 23 309 GTi Torsion bar £59.40 2414 96 Gear Rod Long £21.09 2454 95 Gear Rod Short £7.89 2452 46 Gear Rod Medium £12.33 Share this post Link to post Share on other sites
RossD 43 Posted July 2, 2007 If you sign up to the free part (just register) http://service.citroen.com then most of the part numbers come up with a price when you punch the part number into the "Basket" section. Some of the parts that are exclusive to the GTi (ie not shared with other models) aren't shown. I mainly use it for engine parts as they are common across Peugeot and Citroen to a certain extent. Bonus is, if a price does come up, its the latest most up to date price Share this post Link to post Share on other sites
oli-pug 6 2 Cars Posted July 2, 2007 1.9 gti hub nut, lock nut and r-clip - £5.80 + vat Share this post Link to post Share on other sites
ady 3 Posted July 3, 2007 509442 - Antiroll bar bush L/H £3.05 509443 - R/H £3.17 24250 - Oil temp sender £14.61 cheers for the input guys! Share this post Link to post Share on other sites
Edp 67 3 Cars Posted July 4, 2007 1109 N2 OIL FILTER £8.31 1131 14 OIL PRES SWITCH (LIGHT) £18.32 1131 69 OIL PRES SENDING UNIT (SW) £55.45 1267 12 FAN RESISTOR £16.27 7410 99 REAR BUMPER £80.73 7401 73 FRONT BUMPER £111.14 Share this post Link to post Share on other sites
Edp 67 3 Cars Posted July 5, 2007 Power to the people! Share this post Link to post Share on other sites
chris 417 mi 29 2 Cars Posted July 8, 2007 Mi16 bits : Thermostat gasket : 1340 30 £1.46 (only come in 5's) Thermostat : 1338 03 £12.99 cam cover plug lead cover : 5979 78 £10.12 Gti bits: Slampannel : 7106 87 £16.74 Headlight adjustor/ corrector : 6224 a1 £19.14 Cant remember which these were but its roughly all the copper lines on the car Brakehose : 4803 k4 £13.50 Brakehose : 4803 48 £10.49 Brakehose : 4803 e4 £11.83 Brakehose : 4803 45 £10.49 Brakehose : 4803 f2 £9.54 Brakehose : 4803 51 £13.28 Pressure regulator : 4861 49 £40.00 306 Brake fluid reservoir : 4643 34 £27.85 Reservoir cap : 4643 34 £2.35 Slam pannel lock : 7934 30 £8.44 speedocable : 6123c5 £19.24 Headlight support (not sure which side) : 622316 £ 6.30 Headlight support (other side) : 622316 £6.30 Speedo cable rubber pin thing : 265007 £1.53 radiator housing : 1308 e9 £88.55 Heater matrix : 6448 g1 £41.42 grille badge : 2649 11 £7.80 clutch cable : 2150 a7 £18.90 metal water pipe (to rad) : 1307 78 £11.95 washer reservior : 6431 42 £10.22 Reservoir pump seal : 6434 45 £1.75 High note horn : 6236 81 £19.10 Oil drain sump plug : 1639 3 £0.82 black drivers wheel arch cover : 7213 67 £9.92 Share this post Link to post Share on other sites
pugbliss 0 Posted July 12, 2007 more 205gti bits.... 24246 ecu temp sensor £16.75 (ouch) 180904 flexible bush ( bush in rear engine siport yolk) £5.41 185416 suport yolk for rear engine mount £27.47 Share this post Link to post Share on other sites
TB_205GTI 1 Posted August 29, 2007 you do know that Peugeot has launched servicebox right? There you can get complete spareparts catalogue AND prices, for free.. Share this post Link to post Share on other sites
Spiky 37 Posted August 29, 2007 306 gti-6 rear shocks, 5206 k6 33+vat each Share this post Link to post Share on other sites
philfingers 5 Posted November 26, 2007 www.peugeotparts.co.uk genuine parts at factor prices. I've bought a few things over the years: Prices (pounds, roughly!) PP: dealer Clutch 45: 125 Lower steering coupling (PAS) 45: 130 tie rods 18:32 rear box 45:130 Big savings and the service is spot on, clutch, st joint and tie rods came in Peugeot packing too Share this post Link to post Share on other sites
welshpug 1,627 Posted November 26, 2007 thats neat autos isnt it? do you know if they have a price list as their web prices haven't been updated for some time. Share this post Link to post Share on other sites
philfingers 5 Posted December 1, 2007 no, completely different place. The one is in Yorkshire and the other in Middlesex! Share this post Link to post Share on other sites
GLPoomobile 958 Posted January 2, 2008 I don't think this one has been posted yet, and it's one of the most popular parts to be mentioned on the forum!! Front wishbone bush kit (ALL bushes and nuts/bolts/washers required to replace front wishbone bushes on both sides ) - 3599 07 and costs circa £17. Share this post Link to post Share on other sites
welshpug 1,627 Posted January 16, 2008 I forgot about this thread and posted a new Topic yesterday!! details for 205 GTI Driving/Spot lamps, NOT FOG LAMPS http://forum.205gtidrivers.com/index.php?s...mp;#entry768328 Share this post Link to post Share on other sites
ham149 0 Posted January 21, 2008 fog/Driving light bracket : pn. 7416.05 price £1.96 each Share this post Link to post Share on other sites
chrisj21 2 Posted April 10, 2008 full set of trim clips to do the whole car ie rivets,slider clips ect. 6994.44 just under £29.00 inc vat Great topic chaps! Share this post Link to post Share on other sites
