Pob
Water Leaking In
Pob
Hi all,
I've read a couple of posts about this, but not sure if its the same as mine.
Today I noticed the sound proofing was wet on the passenger side, so I removed all the seats, took the carpet out and binned the sound proofing. The sound proofing on the bulk head (Foam stuff) was wet behind it particularly behind the panel on the left (With the bonnet release catch on it) What could be causing water to come in?
Many Thanks,
Dan
chrisj21
Im in the process of stripping my shell down at the mo and have also found damp soundproofing.mainly in the passenger side rear footwell,it was coming through the door seal where it joins at the bottom.
if i was you i would make sure you check the water hasn't got under the paint and rusted through the floor as mine had :angry:
hope this helps :rolleyes:
Pob
I've removed the carpet, and there was water coming through the seam sealer on the inner sill... I've cut it out and going to re-seal it. I've also found a small hole in the floor, but it doesn't go through. Going to plate it. Is there anything on the passenger side bulk head that can leak?
Thanks,
Dana
steve@cornwall
Thanks,
Dana
The fan motor is sealed with a foam type gasket which by this age has usually degraded. I'd use silicon to re-seal but it ould be a b***er to remove later :rolleyes:
Check that the drains at the bottom of the wings and top of scuttle panel are clear as if not this will allow water ingress via the heater motor
Pob
Hi,
Thanks for all the replies... I've had a look today where the water is leaking in. Its was coming behind the seam sealer, I cut it back and its leaking from the panel on the passenger foot well on the left where the bonnet catch bolts onto it. Its coming from the edge of that panel in the corner near the bulk head. Has anyone had this happen before? How can I stop it? I could re-seal it with seam sealer, Any suggestions?
Thanks,
Dan
steve@cornwall
Hi,
Thanks,
Dan
Should be drain slots at the bottom of the wings, poke something up them to see if they are clear!
Pob
Hi,
Water does pour out of the bottom of the wing, but it also trickles inside :unsure:
Dan
Super Josh
The seam sealer shrinks and cracks with age. Just put some new stuff in :unsure:
Josh
Pob
Thanks for the replies and the information, much appreciated.
Today it has been raining quite heavily and I've noticed that water is leaking in the rear windows. I have ordered new seals for the windows, so that will cure it. But I've noticed that water is getting into the sills, is this coming from the window seals leaking?
Many Thanks,
Dan
