Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Cylinder Liner Protrusion Too Much - What To Do?
  • Please log in to reply
21 replies to this topic
#1
Gaz-2006
Gaz-2006
  • Drivers
  • 33 posts
Hi all,
I have recently rebuilt my engine and had a coolant leak from the head gasket, upon removal of the head I re-checked the cylinder liners protrusion (the liners are the originals for the engine but have been re-honed) and they are about 0.5 mm where the tolerance is a maximum of 0.1 mm with a minimum of 0.03 mm....
I was wondering if anyone has encountered this issue before, and how they went about correcting the protrusion to bring it within spec?
I would obviously like to avoid stripping pretty much the whole thing down and would like to fix it without removing the pistons and liners from the block.
I'm personally thinking along the lines of trying to 'rub down' the liners with progressive use of wet and dry paper to achieve the correct protrusion whilst plugging the bores with blue roll to prevent anything getting into the bores...
Any other suggestions are welcome but would also be nice to hear from anyone who has experienced the problem themselves!
Best Regards
Gary
#2
Bally
Bally
  • Veterans
  • 537 posts
Where was this coolant leak. .005 shouldnt cause that problem.
#3
Gaz-2006
Gaz-2006
  • Drivers
  • 33 posts
The coolant leak was all the way around the cylinder head and it was 0.5 not 0.05mm :)
#4
Gaz-2006
Gaz-2006
  • Drivers
  • 33 posts
Any ideas?
#5
lagonda
lagonda
  • Drivers
  • 790 posts
  • Name:Laurence
Seems rather strange IF these are the original liners to your block. When I rebuiilt mine, the worry was too little (but just enough!) protusion. Would have thought most likely a piece of crud preventing proper sealing ... did you scrupulously clean the barrel & block faces where the O ring sits ... this is absolutely essential.
If all else fails & you are absolutely certain the barrels are too tall, the only option will be to measure the difference accurately & get each barrel machined down. You'd nead several million years to rub them down with emery, & then they probably wouldn't be true.
BUT check & double check that you have no alternative ... metal removed can't be added.
#6
  • Pitcrew+
  • 29,445 posts
  • Name:Mei
get some large washers and bolt the liners down, then re-check the protrusion.
#7
Emmy Seize
Emmy Seize
  • Drivers+
  • 280 posts
Did you mean check it, while the liners are clamped down ?
You´re not supposed to do that - never not!
My guess would also be that the liners do not sit properly in the block, yet.
Debris could be one reason, so take the liners out and clean all the surfaces.
The "Revue technique" suggests you could also try rotating the liners by half a turn and measure again.
A gentle tap (and I mean gentle tap) with a plastic hammer may help as well.
Recommended tolerances differ from manual to manual as from engine to engine.
The ones I found read 0,08mm to 0,15mm with a variance from liner to liner of 0,05mm.
Biggest problem might be the variance between the liners anyway, so if you are sure the liners belong to the block and you don´t find any means of reducing the amount of protrusion, just make sure they are all even and fit the head nevertheless.
#8
ALEX
ALEX
  • Drivers
  • 2,690 posts
Garage View Garage
As suggested check that the liners are seating properly in the block.
I'm unsure of this, but are you supposed to check the potrusion with the liner seals in or out?
#9
Guest_Davva_*
Guest_Davva_*
  • Guests
I have read differing advice.
1. measure with seals in
2. measure with seals out
3. measure clamped
4. measure unclamped
& any permutation of the above (& more).
I am sure it can't be that complicated but just nice to know for sure a 100% method!
Edited by Davva, 26 November 2007 - 02:43 PM.
#10
  • Team Managers
  • 18,389 posts
  • Name:Graham
Garage View Garage
Liner protrusion should be measured unclamped with no seals fitted.
Graham.
#11
rnotman67
rnotman67
  • Drivers
  • 31 posts
Graham.
I am in the process of rebuilding my Mi16. Had the crank away to get regrind. The blocks sittin on the stand stripped and ready to be cleaned. I've not touched the liners thinking they will be okay...
...Until I read this thread.
Where about and how do I measure the liner protusion and seeing as I am here is it wise to just take them out and replace the seal (not sure how easy it is).
#12
Stu
Stu
  • Drivers
  • 1,045 posts
If the crank is out and the block is on a stand i'd defo do the liner seals, they are pennies mate and the last thing you want is to reassemble it all to find they are leaking.
Remove the liner, (noting the position and orientation), clean up the seat(s) and drop it back in. In the absence of anything better use a known good straight steel running across the liner onto the block in the upright position and see how much the liner protrudes the block by getting a shim/feeler gauge in between the block and rule.
If its low the block may need machining, if its high the liner needs machining. Make sure the gasket face of the block is immaculate before hand, and that the top of the liner is mint too else it wont be an accurate test.
Dont be scared by it mate, it sounds horrible but 90% of the blocks/liners ive come across have been within tolerance. If your feeling particularily adventurous mix and match the liners to get the best protrusion, and rotate them 180 degrees from their original position so that the wear is on the 'back' edge.
#13
Guest_Davva_*
Guest_Davva_*
  • Guests
Graham.
Hi Graham, many thanks for the prompt reply. 'Murphy's Law', we have another 'wee' issue, which is slight corrision on the liner mating surface in the block.
Posted Image
but nothing like as bad as some of the pictures I have seen on the forum.
Some forum members say they have used a thin smear of Automotive Silicone sealant on the mating surface.
One workshop we spoke to said he would try something like
www.lab-metal.co.uk but is there a 'recommended' solution?
#14
rnotman67
rnotman67
  • Drivers
  • 31 posts
Magic cheers Stu. What should the liner protrusion be when it comes to measuring?
#15
Stu
Stu
  • Drivers
  • 1,045 posts
If i remember correctly its 0.03 to 0.10mm, with a max difference of 0.05mm between liners for 8v engines and 0.02 for 16v engines.
If you do search bud im sure its been covered before, you might even find my post on the subject recently!
#16
Gaz-2006
Gaz-2006
  • Drivers
  • 33 posts
Got to love Peugeot's!..
I have now been forced to use the block from my spare engine which is still not in great condition erosion wise, and about 30-40 thou/1mm needs to be removed from the cylinder liner seat to get it to seal properly, and also the block surface to get the protrusion correct. This is going to send my compression ratio through the roof considering i already had 1.2mm removed from the cylinder head! next question - my standard headgasket thickness is 1.25 mm, I know the motor factors do a 1.5mm gasket, but I will be looking at a 1.75 - 2.00 mm gasket now to bring my compression ratio back within check.
Any ideas on that?
Gary
#17
Mikey S
Mikey S
  • Drivers
  • 893 posts
  • Name:Mike
Garage View Garage
Any ideas on that?
Gary
i doubt very much you will be able to get a standard gasket @ 2mm thickness. maybe a solid copper gasket?
#18
Gaz-2006
Gaz-2006
  • Drivers
  • 33 posts
I was thinking of that, however i am on a very tight lead time and need a gasket this week/very early next week as the car needs to go to donington for its first test on 7th December!
Anybody had a copper gasket made up before and any idea who would be able to do this for me ?
Any leads much appreciated as I'm getting worried about being able to make my deadline now!
#19
Gaz-2006
Gaz-2006
  • Drivers
  • 33 posts
If i have removed 1.2 mm from the head, and also decked the block by 1mm.. does anybody have similar experience of removing that much material from the head and block, an idea of high the compression ratio will actually be, and whether it will run without pinking on a fairly standard 1.6 8v.. I need to act fast to get this engine back together and I was thinking that if i increased the gasket thickness by 0.25 of a mm from the standard thickness of 1.25mm up to 1.5mm then that will JUST bring me within spec..
#20
Mikey S
Mikey S
  • Drivers
  • 893 posts
  • Name:Mike
Garage View Garage
http://www.ferriday....er/copper.shtml
heard good things about these guys. :)
