tonycj
Can I Get Locks Altered To Suit Different Keys?
tonycj
ive got two keys that i need for my car, one for the ignition, locks and diesel cap and one for the glove box.
What i want to know is, is it possible to get the glovebox lock altered to suit the other locks?
Then ill have one key for the whole car!
Simple!
Cheers,
Tony.
DamirGTI
Hello !
Yes it could be done , I've made a few of my locks so that i can open all of them with just one key ... but it's not so easy job ..
You need to dismantle the lock/cylinder and reposition the balls (each ball is of various/different length ..) inside the lock/cylinder so that they permit opening of the lock according to the new key tooth shape – it's a tweezers and patience job ! because the parts are very small and it's on a bit of trial and error basis until you finally set/match the right combination for the key tooth shape ..
When you remove the lock , on top of it you'll see a little cap sealed around with an epoxy glue - cut the glue around the cap and lift it very carefully upwards (and i mean carefully as if you don't do this gently the balls will fall out from the cap and the cylinder and you'll have a problem finding them afterwards !) and then , when you open up the cap you'll see one line of balls inside the cap and one line of balls inside the cylinder , each ball inside is hole .. :
pics :
The rest is up to you how much patience you'll have with this job :)
Rgs ! B)
Damir
Edited by DamirGTI
DrSarty
Damir,
we are simply not worthy.
Rich
DamirGTI
Hello !
Why not ? ;) I'm sure that most of you guys can do this lock/key conversion but as said it's job for people with patience and good nerves B) try it out , as it's a good amusement instead of watching some boring TV program :blush: .. like puzzle game B)
Regards !
Damir
cybernck
...and i was going to reply "sure, but you'll need a professional to do it" :ph34r::).
Paintguy
That's the easiest way :)
I've done quite a few myself on various models of car, but my best mate is a Master Locksmith, so I usually just give them to him :D
AdamVester
just go down to the scrappy and buy some new locks ;).
Henry Yorke
I have done this with a petrol cap lock before, but I just left all the pins out so any 205 key would fit!
