Stu
Can Arp Big End Bolts Be Fitted In Situ?
Stu
Howdoo peeps,
Ive got a PeterT stage 1 inlet and chip fitted now, with the increased rev limiter, and im starting to get a little worried about one of the stock big end bolts letting go at these sort of RPM's.. So, im wondering if it might be worth investing in a set of ARP big end bolts to set my mind at ease.
Sooo.. can the ARP's be fitted in situ? Or will the pistons/rods have to come out to fit them?
just need to drop the sump off to fit them.
fiji bob
im sure i remember having to have a bit of machining done on the rods/caps for the bolts when i had mine fitted
Stu
Anymore for anymore?
Craigb
How do you get the old bolts out ?
sorr
A swift whack or two with a hammer. Although I left the nut on sitting proud of the bolt to save mashing the threads.
nick
As mentioned above, I'm sure you have to put a chamfer on the hole in the rod with ARP's, so yes new bolts can be fitted in situ but not ARP's.
Nick
Stu
Bugger.. Something else i wish i'd done when i put the engine together.. *sigh*..
So, ARP's need the rod machining to accept?
Usually, yes.
James_m
Nick
I didnt :D No sign of trouble 5k miles on....
luggy
[/quote
Neither did I, biggest issue I had was taking the old bolts out.
brumster
Same here - went straight in, no issues (on XU9J4 stock bottom end, though, should they be any different...?)
fiji bob
it was xu9j4 rods that i had arp bolts fitted to from what i remember they almost fit but probably need slight machining to fit properly
