AdamP
Tyre Pressures, Acb10s
AdamP
I'm running 6/21 R13 Avon ACB10s on 13x5 rallye steels. Car weighs around 700kgs (completely stripped out roland garros, polycarb windows, no sunroof etc), and I have absolutely no clue as to what pressures I should be running. I've been told around 26psi, and also around 16psi. Had them at 26 on the weekend and they did seem a little 'over inflated'.
Any ideas?
Adam
swordfish210
well they have pretty hard sidewalls so you can get away with a much lower pressure. I know it's not the same but we used to run 14F and 16R on the Formula Fords. I would try 22F and 20R, see how that feels.
AdamP
I thought around 20 would be sensible. Will give it a try on the weekend (prescott hillclimb!).
James_R
I ran 26Psi in them cold on my 205 stripped caged still with glass, 8v in it.
