autograsser 0 Posted October 16, 2008 anybod got a wiring diagram for a 1.6 gti?? they could email or put a link to? Share this post Link to post Share on other sites
welshpug 1,626 Posted October 16, 2008 try this http://www.buzzboxx.co.uk/Haynes_205.pdf which parts are you looking for specifically? Share this post Link to post Share on other sites
autograsser 0 Posted October 21, 2008 gonna be striiping apart the loom for the track car am removing anything it doesnt need on the loom to run Share this post Link to post Share on other sites
Cameron 16 Posted October 23, 2008 (edited) This could help you, it's the diagram I made when I re-made my loom. Cut out everything I didn't need, so it's just lights front and rear, fuel pump / gauge and front wipers. I can send you a larger pic if you want as this might not be very clear. From left to right, front lights, front wiper, engine loom plug, dash, indicator / wiper stalks, headlight / wiper / flasher relays, hazard / fog switches, power switch, fuel pump, rear lights. Edited October 24, 2008 by pugtorque usual thing, image filesize outside requested limits, changed to thumbnail, click for full size. Share this post Link to post Share on other sites
autograsser 0 Posted October 23, 2008 that looks like it took some time!! dont suppose you could scan it and email me it (if i said pretty please) or photo copy and post??? pretty please Share this post Link to post Share on other sites
welshpug 1,626 Posted October 23, 2008 looks like and old P1 205/309 Haynes/Peugeot wiring diagram every wire on there to make you go Share this post Link to post Share on other sites
Cameron 16 Posted October 23, 2008 Haha it's a bit clearer than a Haynes, the wire colours were carefully planned so none of the same colour cross (didn't work though some had to). The plugs are all numbered too so you know what wire goes to what pin. I don't have a scanner here, but I'm going to my gf's this weekend, if you can wait 'til then I can copy it there? Share this post Link to post Share on other sites
autograsser 0 Posted October 23, 2008 your mint cheers Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted October 24, 2008 Id be interested in a copy of that if you dont mind?? Thanky, Ed. Share this post Link to post Share on other sites
Ron_Jaegers 10 Posted October 28, 2008 I'm interested in this stripped loom as well. Does it have everything to pass MOT? Don't know if the requirements are different over here but should not be too far apart. Still want to be able to drive the streets. It should clean up the car from the inside as there is a massive amount of wiring hanging in mine. Share this post Link to post Share on other sites
Cameron 16 Posted October 28, 2008 (edited) Yeah it passed the MOT just fine, doesn't include rear wiper, washer or screen heater as they aren't deemed necessary. No in-car heater or any fancy stuff either so if you want that you'll have to figure the wiring out as it isn't shown. Anyway, sorry its a bit late.. In my rush to get going on Friday night I forgot to take it with me. I took some photos and they seem to be pretty clear. I should add that this diagram is specific to my car so is just a guideline, however if you're building an entire loom from scratch I can't see it causing any problems as long as it is a phase 1.5. There is a wire missing that (i think) goes from pin 6 on the wiper stalk to pin 8 on the wiper relay, I'll have to confirm this once I get a chance to look at my car. Engine bay wiring - I made my own engine loom using a non-standard plug to connect to the main loom so the pin-outs on the engine plug won't match the 205 one. However the pins are labelled with the sensor they go to so you should be able to sort something out. Interior wiring - dash etc Rear interior wiring - rear lights, fuel pump etc. Edited October 28, 2008 by Cameron Share this post Link to post Share on other sites
Cameron 16 Posted October 28, 2008 Except for the relays and hazard / fog switches it's pretty much laid out as you'd find it on the car, but if you get confused with what plug is what then I can make a list for you. Share this post Link to post Share on other sites
